fuel tap mod
- paulb
fuel tap mod
10 years 5 months ago
Hi
some time ago on the uk z1300 site Phil posted some info on how to mod the standard fuel tap to make it easier to operate can anyone tell me if it is on this site because mine has become a right bast##d to operate
thanks
Paulb
thanks
Paulb
- LareNurminen
Re: fuel tap mod
Hi,
I seem to recall the mod was just shortening the screw that holds the cone shaped assembly in place. When the tap heats up, it sticks and shortening the screw helps. I have just added a manual shut-off valve to my fuel line after the original, leaving the original in reserve position. The original tap can leak through in closed position, possibly causing serious damage due to hydraulic lock in cylinder when starting.
Brgs, Lare
Brgs, Lare
- McZed
Re: fuel tap mod
I changed mine to a Pingel fuel tap bought on fleabay. See the fuel line routing thread on here. It was a bit on the expensive side but it is a quality item and a vast improvement on the original.
Z1300 UK
Re: fuel tap mod
The search tab can be a bit of a pain to work with but I found the reference. It was Scotch who had posted a repair to the tap and here's the post.
www.kz1300.com/index.php/forum/carburato...rrghhh?start=30#9008
The following user(s) said Thank You: paulb
- Phil
- 1984 ZG1300-A1 DFI
Re: fuel tap mod
Lare sort of had the correct answer, only I put a washer under the screw head that holds the guts of the tap in (split washer, M5 I think) & that stops the screw bearing so heavily in the groove it protrudes into. I also greased all the sliding surfaces inside.
- paulb
Re: fuel tap mod
Thanks Phil
did the mod a couple of years ago, now the tap is really stiff again so i am thinking a re grease is in order
paul
paul
