Carb tuning, DG 6 into 1 header
- Shelbygt
10 years 9 months ago
I bought a DG 6 into 1 header. Just wondering if anyone has installed one and wondering what jet sizes, etc I'll need?
Re: Carb tuning, DG 6 into 1 header
I've done it.
I purchased a Dyna Jet kit for the carbs for about $125.00. The kit contains two sets of mains, weights for the slides and notched needles. The instructions suggest that you start with 96s for the mains. The stock jets are 110s. I presently have the 96s in use but I had to go to the sixth notch to get a proper mixture. The bike runs great but next time I pull the carbs I'll be installing the 100s and going back to the third notch.
Best of luck!
Best of luck!
The following user(s) said Thank You: Shelbygt
- Shelbygt
- Shelbygt
Hmm. So the smaller the jet size numerically the more it flows? Did you do anything with the air cleaner/air box?
10 years 9 months agoNo the smaller jet flows less fuel. I followed the instructions from DynaJet. They suggested I start with the 96s and truly they worked, although at the sixth notch. I did fit a K&N oiled filter.Shelbygt wrote: Hmm. So the smaller the jet size numerically the more it flows? Did you do anything with the air cleaner/air box?
- Shelbygt
Okay I see. Can you do a jet change with the carbs on the bike?
Time to create page: 0.133 seconds
