Before and After
  • PKZ1300
  • PKZ1300's Avatar Topic Author
Re: Before and After
8 years 1 month ago
#21208
I have had the fuel/oil contamination happen on other bikes but always checked the site glass on the clutch cover where I knew it was an issue. Having said that I know I've run my GPz750 and Ducati 900MHR with oil contaminated by fuel with a lock up. Problem on my Z1300 is when I cleaned her up I couldn't find a 6 litre clutch cover so have a 5 litre one, so doesn't read as true. I guess the other alternative is to keep the fuel tank empty but for the time being I'm happy with the fuel system integrity.............
8 years 1 month ago
#21211
Clutch-cover ! or ......Oil-pan ?
  • PKZ1300
8 years 1 month ago
#21282
No the cover with the fill hole in it. From what I can tell there are three different ones with different oil capacity written at the top.
  • RChaloner
  • RChaloner's Avatar
8 years 1 month ago
#21284
I thought the sump oil capacity was only a function of the sump casting (the oil 'pan') and the matching oil pick-up pipes perhaps, but do you think it requires a different clutch cover too?
The oil level sight-glass is not much higher than the bottom of the clutch cover, so I didn't think it can affect oil capacity, but was your point that you think the sight-glass may be at a different height on different versions of the clutch cover?
I'd always assumed the data cast into the cover / scre cap would vary according to the sump capacity fitted to that particular model, but not have any actual difference in it's dimensions.
Can anyone confirm?
1979 KZ1300 A1
#21286
I have two clutch covers in front of me. I don't know what models are they from, but the one with larger oil level viewing window has 5.3 liters on it, the other with small window has 4.6 liters written. Other than that, when it comes to capacity of these covers, they are completely identical, same capacity.
Last edit: 8 years 1 month ago by StanG.
  • RChaloner
8 years 1 month ago
#21288
Out of Interest Stan, and perhaps to answer PZ's point, if you hold the two covers side by side, given that they have different sight-glass sizes, is there any difference between the two sets of min / max lines by each glass?
I'm guessing not, but...
1979 KZ1300 A1
Time to create page: 0.225 seconds
