Old Friend
  • Mellvis
  • Mellvis's Avatar Topic Author
Re: Old Friend
11 years 5 months ago
#7522
Got the carbs off tonight. Didn't have much time to play so I only got two of the float bowls taken off. W.O.W..... I can't remember the last time I saw jets that looked that nasty! I have to spend some time getting rounded screws out of the other bowl. I think I'll just replace the old jets rather than try to clean them. Anyone ever soak WD-40 on the jets to help loosen them? Going to try it.
Re: Old Friend
#7523
The following user(s) said Thank You: Mellvis
  • Mellvis
Re: Old Friend
#7552
Scotch, is there a trick to removing the emulsion tubes? I threaded a screw into them and the slid further into the carb bodies very easily, but would not pull up out of the jet towers. Am I missing something? I didn't see this in your carb cleaning thread (Which IS very helpful, thank you).
Re: Old Friend
#7553
They come out through the top of the carb. there's a step at the top of the emulsion tubes and basically, the main jet holds them in. push them up from the bottom.
  • Mellvis
Re: Old Friend
#7556
Well, didn't thank of that! Thank you much!
  • Mellvis
Re: Old Friend
11 years 4 months ago
#7629
Well, carbs are all nice and clean! If only I hadn't dropped that tiny little pilot jet in the gravel driveway........
New one ordered today. Now it's a waiting game. Life is great/sucks.
