Waterpump mechanical seal.
ZN1300 Rad Hose
2 years 9 months ago
Not sure the ZN1300 and the KZ1300 use the same rad hose - the part numbers are different - but I'm curious, since the OEM hoses are NLA, what hoses are you guys chopping up to work with your KZ1300's?
- zed_thirteen
Re: ZN1300 Rad Hose
I bought an off the shelf silicone hose with a 135° bend and a straight silicone hose. As it turns out there was plenty left over after cutting the top hose to make the bottom hose
Re: ZN1300 Rad Hose
2 years 9 months agoAny chance you have a part number or fitment list for the hose you used?I bought an off the shelf silicone hose with a 135° bend and a straight silicone hose. As it turns out there was plenty left over after cutting the top hose to make the bottom hose
Re: ZN1300 Rad Hose
It's as simple as doing a "SEARCH" !
www.kz1300.com/index.php/forum/engines/8...t-radiator-hose#5599
- zed_thirteen
Re: ZN1300 Rad Hose
2 years 9 months agoI got mine from autosiliconehoses.com (£7.86 + £3.25 shipping):Silicone Polyester Reinforced Hose - 32mm - 45 Degree Elbows - 15 ColoursSKU: P SSE 045 032 KColourBlackI bought an off the shelf silicone hose with a 135° bend and a straight silicone hose. As it turns out there was plenty left over after cutting the top hose to make the bottom hose
Re: ZN1300 Rad Hose
1 year 11 months ago - 1 year 11 months agoI'm still following up in this. I think I've found a suitable hose, but I've read some stuff on silicone hoses needing special clamps. Did you reuse the OEM clamps?I got mine from autosiliconehoses.com (£7.86 + £3.25 shipping):Silicone Polyester Reinforced Hose - 32mm - 45 Degree Elbows - 15 ColoursSKU: P SSE 045 032 KColourBlack
Last edit: 1 year 11 months ago by Bucko.
