Engine temp sensor
  • pin
  • pin's Avatar Topic Author
Engine temp sensor
5 years 11 months ago
Hi
does anyone know where I can get a engine temp sensor for a zg dfi or is there a Different one from something else I can use
Thanks
Andy
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: Engine temp sensor
Sorry pin,
I've been working out of town and not on the computer at all. I've approved your post and deleted the duplicate. I'll need to approve one more post and then you may post at will.
Welcome to KZ1300.COM
  • Bar
  • Bar's Avatar
Hello Pin,
which one you referring to?
Temperature Sender or Fan Temperature switch
you can find all of them at zed-parts.com
below is for Voyager, but if it not the same I'm sure they have it
www.zed-parts.com/product-page/92066-1028-temperature-sender
www.zed-parts.com/product-page/27010-1036-fan-temp-switch
Thank you
Eran
1984 Kawasaki Voyager
2002 Honda CBR954
Last edit: 5 years 11 months ago by Kawboy.
  • pin
Thanks
I’m new to the Z1300 and so far finding parts are hard To find ,and right now I don’t know what parts I need so I’m just working my way through the list
  • Stiggy
  • Stiggy's Avatar
  • March 1961
Is it the sensor for the DFI module or the one which for the temperature gauge.?
If it's the Dfi one, a 2k ntc thermistor will provide the same functionality. You will just have to mount it into your old sensor body. Lots of 2k ntc thermistors on fleabay...like this....
Item number 264397325810. They are tiny so can easily be fitted into a drilled hole in your old sensor. Use epoxy to seal out moisture and give the connection support.
Hope this helps.
1985 ZG1300 dfi
  • petersmith98
  • petersmith98's Avatar
Hi. I am using Z1300 so far. it's so good. I'm very reassured ..
Time to create page: 0.096 seconds
