Any Progress on Cheap Generic U-Joint Boot Replacement?
- rdurost
6 years 10 months ago
Most of the references on the site are old.
Yes, I know there is a limited-production part available from the Netherlands for $80 shipped to the USA. It looks like a great part, and kudos for anybody making a replacement at all. It just seems like with the vast numbers of these sort of devices being used in all kinds of applications all over the world, a mass-production replacement should pop up eventually.
Kawasaki KZ1300, Z1300, ZG1300 U-joint cover 49006-1020
Inner diameter of mounting area 97 mm (3 13/16)
Outer diameter of accordion area, 125 mm (about 5")
Length 75 mm (just under 3")
Richard
Richard
Re: Any Progress on Cheap Generic U-Joint Boot Replacement?
6 years 9 months ago
Many years ago I looked into this and I found a CV Boot Kit from a 4x4 Car which was ideal when cut down the correct length as a replacement boot.
It even came with 2 metal straps which fitted perfectly on each end and looked 95% stock when fitted, as you cannot see much of it anyway.............
Only problem is I cannot find any reference in my emails etc as to which model of 4x4 it was, but its worth a look at any good motor factors or parts suppliers to compare them against the original ???
- rdurost
How about a "slip joint boot?"
Putting aside the question of the inner diameter of the ends, the basic layout seems the same, I think some of the big diesel consumer trucks use these.
www.merchant-automotive.com/12471527-Pro...p-Yoke-Boot-Kit.aspx
