overheat
Re: overheat
You've got a full Rad.
You've got coolant in the reservoir.
You've got a fan that does come ON.
You've got a temp. gauge that apparently shows a FAST rate of increase in coolant Temp.
Now for the "stupid" question: Are you sure the water-pump impellor is spinning?
One possibility:
If the c-clip has come off it might be that the impellor has moved forward on the shaft, disengaging the "Tabs" on the shaft, from the slot in the back of the impellor. The seal would still be in contact ( you haven't mentioned any leaks from the "Bleed-hole"), thus putting the water-pump impellor in contact with the impellor cover. There is very little space between the impellor blades and the impellor cover but there could be enough to allow this scenario.
The other possibility is the Water-pump shaft "Tabs" that engage into the back of the impellor, have corroded away enough to grind-out the "slots" in the impellor. The shaft will spin but with no means of engagement the impellor is not turning.
Worst case scenario - The Nylon drive gear is stripped.
Other then that.......:huh:
One possibility:
Last edit: 7 years 4 months ago by scotch.
Re: overheat
7 years 4 months agoOther then that.......:huh:
0ther than that - a couple photos to illustrate this! lol
How about starting the engine with open radiator cap? The coolant level should come up - it would mean the pump is spinning. You could also loosen the hose with the cap closed and see if it starts leaking with pressure.
- zed_thirteen
Re: overheat
7 years 4 months agoStanG wrote:Other then that.......:huh:
I've had this wear issue. lobes corroded away on shaft and back of impeller worn away. New CNC impeller from Germany and a work colleague welded up the lobes on the shaft and then turned them back to proper dimensions
- Tad
Re: overheat
Cheers guys
No water leaks at all
Radiator gets hot so i would have thought impeller was turning as if not the engine coolant would fry pretty quick
Ran it up today for 20 minutes on idle and although red hot on guage, when fan is running it does not boil up.
I will check impeller anyway.
I am also going to get a themo strip and see how hot the rad core is.
Have heard about the plastic gear failing. Is it a pig if a job?
Tad
- Tad
Re: overheat
Ps. Its normal i guess for the fan to run a while when ignition switched off?
Tad
Re: overheat
Yes - the fan will run when the key is off. It might do a couple times. Quite funky when you park and cover the bike! It rises up like a heated balloon! haha
The plastic gear - you'd need to take the head off. It's not that bad. It also creates an opportunity to check and service a few other things. And parts, like recommended Kawasaki head gasket, are expensive. But it's not a very bad job.
To add one more thing - I installed a ZN temperature sensor. It kicks in at lower temperatures. Pretty much I never see the temp. gauge showing more than a bit over half way.
