Fan override
- Badger
Fan override
6 years 11 months ago
Can I interrupt the fan switch to manually activate the fan at slow speeds?
Re: Fan override
The fans' thermostatic switch simply grounds the circuit (when the coolant temp. is high enough to activate this switch (sensor), completing the circuit. To add a manual activation switch simply connect another wire to the fan sensor , run it through a on/off switch and ground the other side of the auxiliary switch.
- Badger
