84 voyager dfi need help identifying what wiring diagram to use.
- Rage10
7 years 6 months ago
Hi all,
Picked up a 84 voyager dfi a few weeks ago. It does not have any gauges. I'm going to mount an acewell 6653 cluster on it but I need the wiring diagram for it and I'm not familiar enough with the different models to figure out which one i need.
Thanks in advance,
Isaac
Thanks in advance,
Isaac
- Rage10
Re: 84 voyager dfi need help identifying what wiring diagram to use.
Just for clarity I need help identifying the correct wiring diagram for the bike not the speedo.
I believe any wiring diagram up to and including 86 should work. In 87 (and 88) they added cruise control so that would have changed a few of the wiring bits (there was a CC indicator added to the speedo cluster) but even a wiring diagram for that year might suit your purposes.
Last edit: 7 years 6 months ago by Bucko.
- Rage10
Hmm... well that adds another question. What would I have to do to add CC?
- Rage10
After doing some research, the CC is just a fuel/air mix adjustment. I'll pass on it.
The ECU of earlier models, 86 and down, had a selectable 'cruise' mode which leaned out the fuel/air mixture to improve gas mileage. The 87 and 88 models came with 'cruise control' for holding a constant speed.
