Carb Sync Adapter size- 5mm vs. 6mm
  • Ted
  • Ted's Avatar Topic Author
5 years 3 months ago
#29251
Having recently acquired a 1300, I will be syncing the carbs soon and found them on Z1 Enterprises, but need to know if the port is 5mm or 6mm.  Does anyone know for sure?
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: Carb Sync Adapter size- 5mm vs. 6mm
#29252
Hi Ted,
I'm currently out of town on an assignment. I'll return home on the 5th, Saturday and will answer your question then if someone else hasn't answered you already.
Regards
  • englishcw
  • englishcw's Avatar
#29257
Happened to be working on my Carbs . 6mm .
The following user(s) said Thank You: Ted
  • Ted
#29285
I bought a set of 6mm adapters and verified that they are the right size.  This case is solved.
