Diaphram washers missing.?
- Tad
Re: Diaphram washers missing.?
7 years 4 months ago
Stan ace mate
Want them now. Are you usa?
Tell me the cost and how you want paying
Tad
Is it right the manual setting for idle mixture screw is wrong and they should be 4 full turns out
Typically I have always started with an arbitrary 3.5 turns. If you have a "Color Tune" then you can adjust from there; more or less as indicated by the color.
What you end up with will depend entirely on the uniqueness of your engine/components and set-up of your engine. Don't despair over a difference in the individual pilot- needles. "+" or "-" .5 turns, I don't consider unusual. Any greater difference may require some investigation. Bottom line: If it starts easily, and idles smoothly then your pilot needle adjustment is OK.
Last edit: 7 years 4 months ago by scotch.
- Tad
thanks
any idea why the manual states 1.5 turns. this would be correct for my z1000a1 . what happens at 1.5 turns on the z13. ?
Tad
Ah yes......The mystery behind the manuals' 1.5 turns. No one seems to know! I've got an idea that revolves around the prototype carb, pollution regulations and the timing of the manual being written and printed. It's a moot point. At 1.5 the engine won't run because it's too lean.
Tad - they are ready
I will follow up tomorrow with shipping costs in the PM.
Stock on the right for reference.
The original stock Kawasaki washer is actually plain Derlin as well. I remember seeing some in the past that I also thought had some sort of cloth inside them. I'm not sure if that was an illusion, but this one doesn't. Perhaps different years had slightly different washers if that was the case. Bottom line is it's plain Derlin, and the new replacements I offer are plain Derlin as well. The stock washers are most likely discolored brown due to age and fuel exposure.
Last edit: 7 years 4 months ago by StanG.
The following user(s) said Thank You: scotch, Tad
Look familiar?
I had a missing washer and fabricated one from a reed valve kicking around.
I know someone on the site had lost one and I made him up one and sent it to him. Maybe it was you Stan?
Time to create page: 0.050 seconds
