Mixture screw rubber o rings 5 years 1 day ago #23966
  • StanG's Avatar Topic Author
  • User is blocked
  • User is blocked
  • Thank you received: 248
Just so you guys know exactly.
Last edit: by StanG.
Mixture screw rubber o rings 5 years 1 day ago #23967
  • User is blocked
  • User is blocked
Missing these thin duracon washers (92022 - 1155) or damaged? I will have them (left: old, right: new)
Mixture screw rubber o rings 4 years 11 months ago #24040
  • Thank you received: 242
Have you had those washers specially made, Stan?
Mixture screw rubber o rings 4 years 11 months ago #24043
  • User is blocked
  • User is blocked
Yes and no. They are perfect size except the outer diameter, which I cut with a scissors to the correct size. What I need is to find someone local with lathe, make a 'bolt' to keep a bunch together, and machine the outer diameter at once. A very straight forward thing. If you just make a set of three it takes a few minutes and inconvenient, and I wasted a couple, but not a big deal. I just cut what I need and the rest is waiting for that lathe. 0r if I find a proper bolt from the get go, I will try doing it using my drill and a woodworking chisel.
Mixture screw rubber o rings 4 years 11 months ago #24066
  • zed_thirteen
  • zed_thirteen's Avatar
  • Thank you received: 137
StanG wrote: Just so you guys know exactly.
Any chance this image could be edited to detail where each size is used?
Mixture screw rubber o rings 4 years 11 months ago #24070
  • User is blocked
  • User is blocked
