Carburetor Kits
- Motocross902
Carburetor Kits
7 years 6 months ago
I'm sure that this topic has been covered many times but I couldn't find a good answer. Who makes the best carburetor kits (ethanol resistant) for these bikes? I have 7 (81s & 82s) that need to be resurrected and they all of course have carburetor issues. I suspect (hope) that one of you KZ1300 fanatics will have an answer. Thank you.
Re: Carburetor Kits
I can't speak for the kits but all of the kits use the Buna-N o-rings. You could buy any of the kits and also buy Viton 75 o-rings for the 3 float needle seats . The brass needle seats have an o-ring to seal the seat to the carb body. A Buna N o-ring in that position will be exposed to the fuel and cause the o-ring to shrink. Flooding could occur as fuel escapes around the needle seat and in to the carb bowl, then flood the engine eventually.
I like the idea of changing out all of the o-rings to the Viton but in reality only the o-ring on the seat is an issue. The o-ring on the carb drain screw on the carb bowl only seals the drain screw to the carb bowl when the screw is open. Once the screw is closed that pathway for the fuel no longer exists.
The o-rings on the idle air jets don't see fuel either so Buna N is fine for them as well.
As for the carb kits, unless they come with new Stock jets you're wasting your money. The only real thing you need to overhaul the carbs is the carb bowl gasket and the Viton 75 o-ring for the float needle seat.
and of course, one of Scotch's flushing tools These are the nastiest carbs to clear circuits on that I've ever worked on
Scotch to verify??
Scotch to verify??
Last edit: 7 years 6 months ago by Kawboy.
Re: Carburetor Kits
VERIFIED by "Scotch" :woohoo:
....and thanks for the plug...you know, for the "Cleaning Tool"
- Motocross902
Re: Carburetor Kits
Thank you for the response! I have KZ1300 passion but little knowledge about breathing new live into these beasts. Any thoughts on head gaskets! Purchased an aftermarket one and soon after the engine was running it was leaking.
- Motocross902
Re: Carburetor Kits
What tools should I have for the carburetors? Looking for all the help I can get. With 7 to get running, I can't afford the lost time reinventing. My goal is to get the 7 KZ1300s and the 2 CBXs running well and then get some buddies to take the herd on a ride. At which time one of the lucky kz1300 with be on a cross country trip!
Thank you.
Thank you.
Re: Carburetor Kits
Re: Carb Tools.
www.kz1300.com/index.php/forum/carburato...-retaining-nut#20255
www.kz1300.com/index.php/forum/carburato...d-pt-1?start=12#5520
www.kz1300.com/index.php/forum/attachment/2920
Last edit: 7 years 6 months ago by scotch.
