Fuel cap lock
- Zed1300
Re: Fuel cap lock
8 years 3 weeks ago
That's perfect , thanks guys...... Got a pin punch and it came straight out to my surprise !!!!
The latch part was jammed with abit of corrosion but freed up, will let it soak for a couple of days and take it up tothe locksmith to get it sorted out with a new barrel / key etc
Thanks again for the help
Cheers ted
Cheers ted
- Zed1300
Re: Fuel cap lock
8 years 3 weeks ago
Hi hillsy
Just got back from the locksmith and he said it can't be taken apart or fixed?
I would settle to have it working but unlock able as yours is so wondering how you dismantled it
Cheers ted
Cheers ted
- tackelhappy
Re: Fuel cap lock
8 years 3 weeks ago
If you can't get it fixed , the cheap replacements do fit and work , but as Scotch mentioned , they have no breather. Maybe the tank overflow pipe allows air into the tank as the fuel is used ? I had a look at the replacements on the german site , and from the small photo they have , they look like the ones I bought - the rather pathetic keys they show sitting in the lock is the give away. Maybe someone who has bought one from them can verify- there are not many options .
Re: Fuel cap lock
8 years 3 weeks ago - 8 years 3 weeks ago
"Everything" can be taken apart ! :woohoo:
The fuel tank must be vented to allow air into the tank as the fuel level decreases. Conversely, if the tank is full to the top on a hot day, the vent also acts as a fuel over-flow. The grommet that seals the nipple to the cap must be in good condition ! Not so important for replacement air to come in as the fuel level drops, but really important for an "over-filled" condition in order to get the excess fuel to the ground via the vent hose rather then leaking from the cap and having that fuel run all over the tank and engine!
Pictures are my '80 fuel cap. I had my cap completely apart years ago to de-gum the lock and don't recall any issues in disassembling or re-assembling it. It appears that Kawasaki changed their design slightly.
While on the topic: You can ensure your vent is clear by running a pipe-cleaner through it. Pictures are self explanatory. Note: Use some tape or place a rag in the open filler when re & re'ing the cap to avoid dropping the cap attachment screws into the tank ! Make sure your string-knots and the twisted loop in the pipe cleaner are secure ! Both ends of the pipe cleaner should be "strung". This way, If one end comes off in the vent you can pull it back out with the other end! To get the string through the vent tube, Tie several knots in one end of the string, insert it into the vent and use compressed air to blow it through. Works like a charm. If it won't then you either have the knots too large or there is an obstruction which will require you to reduce the size of the knot until it will pass through. Use a white or light colored pipe-cleaner to witness any debris. You might be surprised what comes out !
Last edit: 8 years 3 weeks ago by scotch.
- hillsy
Re: Fuel cap lock
8 years 2 weeks agoZed1300 wrote: Hi hillsy
Cheers ted
The circular bit towards the bottom in this pic should pop out revealing the locking wafer for the tumbler. Then you push the wafer up with a pick and the tumbler should pop out the front of the cap:
My lock looks different to yours - here's a link to the thread I made about changing / re-keying locks:
www.caferacer.net/forum/technical/29745-...ion-helmet-lock.html
- Zed1300
Re: Fuel cap lock
8 years 2 weeks ago
Thanks all for the input. I got it home from the locksmith and after studying it figured the cylinder needed to rotate to release but was siezed. Sat at my desk and gave it a spray and a few taps whilst holding pressure on the key and it move slightly. It's now working great but just a little concerned why the locksmith didn't sort it out !!!!!
Thanks again everyone
