Throttle position sensor
- Samootin
12 years 4 months ago
Hi all,
I've got a 1984 Voyager that I just finished restoring and it looks fantastic. However I think the TPS is making the engine hunt a little at idle. I heard that there was a guy in Europe who did some research and found a TPS replacement for the 13s. Does anyone know who this guy is? Or does anyone know where I can get a TPS from? Thanks MIke
Re: Throttle position sensor
Hi Samootin
the only guys I could think of doing this in Europe is Wilfried Büchsenschütz.
Maybe get in contact with him directly:
der6Zylinder@web.de
However as he is not that well with Englisch I recommend to desribe exactly what you need, possibly with
a picture ?
Kepp my fingers crossed for you ...
regards,
der6Zylinder@web.de
a picture ?
regards,
- Samootin
Hi Holger,
Thanks for your help> I know a little german so hoepfully he can help I'll let you know how I go.
Mike
Mike
Hi Mike,
yes please. know that guy in person, will meet him in January again. If you need a translation drop me a note (if not too technical)
- wrgoo56
12 years 3 months ago
After reading your post I started doing so looking. If the one guy does not have any thing there is a few things we can try but it going to take a bit of work. Your throttle sensor reads in milly volts up to 5 volt. It can read back words or forwards. that is the first thing we need to know. 2. you need to take a picture of where the shaft goes in and measure it so we know how big it is and if there is a flat side to it. 3. how far apart the mounting holes are and that way we may beable to cross match it with some thing else out there.
Every thing I am reading its no longer made and it fit 12 different bikes.
I have found there is always a way to cross match something to a discontinued part.
- RickG
I am not familiar with the injection on the Z1300 but is it a Bosch system like some of the early Kawasakis had.
If so check out the BMW K series gear as there is a lot of it around and still available new as well.
