looking for a good engine oil and coolant
  • chrisleo
  • chrisleo's Avatar
Re: looking for a good engine oil and coolant
12 years 6 months ago
#3093
I use Motul 3000 plus 15W50 on all my bikes. Would stick with an oil specifically for motorcycles. With the wet clutch and engine/gearbox combo they have certain extra additives as apposed to Automotive oils. In my opinion, this would be the most important factor.
"Motorcycle oils and passenger car oils are very similar, with the exception of a couple of areas that are key to motorcycle operation. The first area concerns common sumps, or the use of motor oil, to lubricate and cool the transmission. As you know, in a passenger car the transmission is lubricated by an ATF fluid, which has frictional properties required for transmission operation. In a motorcycle, where the transmission may be lubricated by the engine oil, an engine oil that does not have the same level of friction modification (for fuel economy) of a typical passenger car engine oil will provide better transmission performance in terms of transmission lock-up and slippage. So motorcycle engine oil does not contain the friction modifiers of a passenger car engine oil. The second area of concern for motorcycle engine oils is that they tend to shear (breakdown viscosity) more quickly than a typical passenger car. Mobil 1 motorcycle oils are designed to provide exceptional protection against viscosity loss."
Z1300 A-5 - 1984
Z1300 A-1 - 1979
GL1100 - 1982
VMAX 1200 - 2002
Honda CBX1000 1981
