FRONT FORKS 1984 A5
Re: FRONT FORKS 1984 A5
6 years 5 months ago
#26683
TJ wrote: The manual i have is for the earlier models and does not cover the forks with a balance pipe that's why I've asked on the forum.Rocket science it might not be but i figured someone may be able to give a simple explanation as to how they work. I'm sure once they are off the the bike all will seem more clear.If that's all it states in the manual then its not a lot of help to the novice.Once oil is in the forks and back on the bike what's to stop oil passing from one side to the other as you ride ?
The fact that once all assembled the forks would rise and fall in unison keeps the oil in each fork tube from migrating.
The manuals are not the greatest and leave a lot to be desired. The fact that the manuals for the later models refer back to the manuals for the earlier models is undesirable. You should be able to pull out one manual and get on with it and not have to have 2 manuals in order to get work done.
