zero compression !!!!!!!!!!!!!!!!!!!!!!!
  • bobber-edd
  • bobber-edd's Avatar Topic Author
12 years 2 months ago
next stage ive got the zed to turn over for the first time in 16 years but there's no compression is this down to no oil in the tappets and they have bled down or what should i do now ???????????????
zed 13 1979 A1 model
  • kwak1261
  • kwak1261's Avatar
Re: zero compression !!!!!!!!!!!!!!!!!!!!!!!
after standing that long you might find some of the valves stuck open and some of the piston rings stuck.
take the top cover off and check the valve clearances first .
drop a bit of light oil down the bores as well
Ian
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
The following user(s) said Thank You: bobber-edd
It certainly won't be "no oil in the tappets" as these are not hydraulic tappets.
Good luck with finding the cause.
  • bobber-edd
yeah there's no compression on any of the 6 cylinders
  • DannyKZ
  • DannyKZ's Avatar
How did you get the engine to break free?
Danny
  • bobber-edd
break free ??? it was never stuck or seized it just turned over
