Z1300 SMOKES.
  • yellowperilbikes
  • yellowperilbikes's Avatar Topic Author
Re: Z1300 SMOKES.
6 years 5 months ago
Thanks for that. Worth a try. Will have a go. Smoke is not just a bit is significant. Is almost like a feed....
  • stocktoy
  • stocktoy's Avatar
Re: Z1300 SMOKES.
going back to look at your pictures it looks like the right side pipe is showing more oil then the left side any chance you might have a broken ring or two? I know your tests indicate good compression.
  • yellowperilbikes
Re: Z1300 SMOKES.
Both sides smoke quite badly, but right stays worse. Strong possibility some one done the wrong thing putting it together! May have got all ring gaps and fitting wrong.....plus damaged an oil ring. Has to come apart whatever.
  • stocktoy
  • stocktoy's Avatar
Re: Z1300 SMOKES.
Well once you get it sorted out you won't be disappointed with your bike nothing sounds like or pulls like a KZ1300.
  • yellowperilbikes
Re: Z1300 SMOKES.
This my eighth one. Never had any issues with the others. Must have been lucky. Nothing nasty out the breather pipe at all.........Pot 4 has a cold pipe, can only assume that plug is major compromised. That coil runs 3 and 4, and 3 is hot. Plug swops does nothing. Is not just some wispy smoke, talking issue. Harley dealer must have had a party when bought this. He must have hung a battery on and fired it up at some point. Was a trade in.....probably by idiot who cocked up an engine job. When took sump off was huge 2.5" bolt lay in the bottom!
Re: Z1300 SMOKES.
If you have a workshop, and suitable tools, plus the service manual, why not have a go at fixing it yourself? It’s amazing what can be achieved with patience, time, a clean orderly approach, and of course the help from the knowledgeable members of this forum.
