Manual Timing Chain Adjuster Initial Cold Setting
Re: Manual Timing Chain Adjuster Initial Cold Setting
6 years 6 months ago
I modified my stock tensioner with an internal nut, retained the internal original spring and locking collar. I rely on the spring to pre-load while giving the crank a bit of C.W. rotation. Then tighten the outside lock-nut. I do not "add" any tension. Still have 'teeth" on my nylon sprocket. 80,000+K
Time to create page: 0.036 seconds
