Here's The Difference Between Synthetic And Normal Motor Oil
  • stocktoy
  • stocktoy's Avatar Topic Author
8 years 5 months ago
The following user(s) said Thank You: scotch, roadhazard, Tonto, Dion
  • PKZ1300
  • PKZ1300's Avatar
Re: Here's The Difference Between Synthetic And Normal Motor Oil
The guy who works on my Guzzi LM3 tells me that viscosity is one thing its the additives and blending that the retailer does that makes the bigger difference. There is a reason why some oils are cheaper than others. On another forum for Suzuki Katana's guys swear by Penrite 15w-50 diesel because of the extra zinc providing more protection. The Guzzi guy reckons Penrite is rubbish and so it goes on and on. But of course opinions on oil are like bums.......
  • BigSix
  • BigSix's Avatar
I would have started this topic with a warning. Discussing the "right" oil is like talking about religion or politics, though I believe that the majority agrees on the difference between mineral-oil and fully synthetic oils.
A difficult topic, so thanks for the input.
The following user(s) said Thank You: Phil, Raygun
  • Phil
  • Phil's Avatar
  • 1984 ZG1300-A1 DFI
I tried fully synthetic in my ZG many years ago; oil started weeping from the rubber cam half moons & the clutch started to slip. Been using semi-synthetic since, been fine.
  • Raygun
  • Raygun's Avatar
Phil wrote: I tried fully synthetic in my ZG many years ago; oil started weeping from the rubber cam half moons & the clutch started to slip. Been using semi-synthetic since, been fine.
I had a similar issue. I run Rotella T4 15W-40 in all my motorcycles and dirtbikes. Never had an issue. But like the previous poster said, oil talk is like religion and never really accomplishes anything. I've also found that the methods to break in an engine has similar feelings.
1982 KZ1300
2003 KLX400SR
1999 KDX220
Wife
Son
Daughter
Cat x 3
  • razmo99
  • razmo99's Avatar
Something I always look at; Is your oil JASO-MA rated.
84 ZG1300
81 KZ1300-A3
83 GT550
90 GPZ900R
83 KZ550
81 KZ550(in parts)
Last edit: 8 years 5 months ago by razmo99.
Time to create page: 0.091 seconds
