z-11cam chain tensioner
Re: z-11cam chain tensioner
9 years 6 months ago
Yes, I agree with using the original tensioner, but with modification:
As Lare stated in his post here: www.kz1300.com/index.php/forum/engines/2234-cam-chain-tensioner
The following user(s) said Thank You: kiwirider
- McZee
I removed the manual cam chain tensioner because it was stiff to turn so I could never be sure the tension was set correctly. I re-fitted the original with the modification that I read about on this forum. The bolt stops the tensioner backing off if the non-return mechanism fails and the original spring keeps it at the correct tension.
Attachment not found
