Cam chain tensioner
  • Craig
  • Craig's Avatar Topic Author
Cam chain tensioner
9 years 8 months ago
I5000 km later and that's what my idler gear looked like! My advice...if your going to change your cam chain tensioner, go the manual tensioner route. I went with the ZZR1000 tensioner and cut the recommended 12mm off the spring and it has still chewed up the gear at a high rate.
  • stocktoy
  • stocktoy's Avatar
Re: Cam chain tensioner
wow that's some wear you sure you're just not too heavy on the throttle lol
  • tackelhappy
  • tackelhappy's Avatar
That is problematic alright- wont do another 15,000 that's for sure.
I have done 20,000 kms on my rebuild , but used the Liska gear along with the ZZR 1100 tensioner.
Had the valve cover off last month for a check over and there is no wear on the gear. It is more noisy than with the plastic gear. Seems there will always be some compromise somewhere.
  • Phil
  • Phil's Avatar
  • 1984 ZG1300-A1 DFI
The original is a goofy design :(
  • LareNurminen
  • LareNurminen's Avatar
I have used the original tensioner with one modification. I have changed the 6 mm. original limiter bolt to one which is ca. 10 mm longer and have a locknut in it. I set the tensioner when engine is hot and then use the longer bolt to lock the shaft, tighten the locknut. Then check once every 3000 miles/5000 km. Has worked fine for me the past 30.000 km.
The following user(s) said Thank You: A1
  • Raygun
  • Raygun's Avatar
Where did you buy the new gear?
1982 KZ1300
2003 KLX400SR
1999 KDX220
Wife
Son
Daughter
Cat x 3
