Bench Testing Ignition Coils
2 years 3 months ago
#32538
Installed new  YellowSquare  ignition coils. Bike still didn't run good.Time to bench test the coils. Search Google.  Find this . Ez pz.
  1. Batt + to coil +
  2. Coil neg to switch to batt neg
  3. Ground spark plug
  4. Hi tension lead to sparkplug cap
  5. Open the switch, primary field collapses, induces hi voltge in secondary, discharges through plug.
  6. But. It doesn't work. No spark. Borrow two auto ignition coils. No spark. Test old Martek coils off KZ1300. These coils had the bike running. But no spark on the bench.
WTFO? Not likely all coils are bad. Must be test set up.
  1. Check all wires for continuity
  2. Check plug resistance
  3. Check switch
  4. Everything checked out SAT
Got to thinking. Auto ignition coils use a condenser to prevent premature point pitting - due to high voltage induced into points. The condenser blocks that voltage. Installed a condenser and voila, spark.
What I don't know is why adding the condenser enables plugs to spark. Could it be the switch, as it opens the primary to induce field collapse and 2ndry discharge is discharging though the switch contact? Or trying to lit the little bulb in the switch that indicates the circuit is powered?
Re: Bench Testing Ignition Coils
2 years 3 months ago - 2 years 3 months ago
#32540
You didn't set up your test circuit properly for a wasted spark coil. From page 237 of the Service Manual
There's a reason the bases of the spark plugs are joined together and only by coincidence are they tied to ground because the cylinder head is grounded through the engine ground.
Last edit: 2 years 3 months ago by Kawboy.
#32541
Thanks for reply Kawboy, my video didn't post correctly so will try again.
You'll see from the video that both plugs are grounded - and that when the condenser is in-circuit, a good blue spark happens.
Let's try to show the video again..
#32542
The spark plugs should be connected to each other, not to ground (I realize you have them connected together at the negative terminal but that's not required).  As Kawboy mentioned, the bike ground (the head in this case), is 'floating' with regard to the coil outputs.  Similarly, the cores of the OEM coils do not need to be grounded in order for them to work (I only mention it as I often read online advice telling people to ensure there's a ground wire to the coil core which is not required for this type of ignition coil (or rather, not required for the OME ignition coils).
Last edit: 2 years 3 months ago by Bucko.
#32547
I applaud the enthusiasm to learn, but feel I need to curb your actions before you damage your coils.
First- The KZ1300 has a redline of 8000 rpm, so the spark event needs to happen in 60 seconds divided by 8000 = 7.5 milliseconds.A spark event is the build up of a magnetic flux, collapsing of the magnetic flux and a discharge of a spark.A typical spark duration for most ignition systems is around 1.3-1.5 milliseconds and there are some ignition systems capable of up to 2.8 milliseconds but for the purposes of this rant, let’s stick with 1.3 milliseconds.So if a spark event at 8000 rpm is 7.5 milliseconds and 1.3 milliseconds is used up in spark duration, they the time left over to build a magnetic field is 7.5-1.3 = 6.2 milliseconds. So the ignition coil has to be able to charge in 6.2 milliseconds or less. Most ignition coils running a 3.0 Ohm primary circuit require 8 milliseconds to build a full magnetic flux.To achieve a full magnetic flux of 8 milliseconds and a spark duration of 1.3 milliseconds (9.3 milliseconds total) works out to 6457 rpm. After that there’s not enough time to create a fully charged spark.So where am I going with this? – The coil is designed to build a full magnetic flux in 8 milliseconds.Energizing the coil for longer than 8 milliseconds will not build any more flux and can likely damage the windings by overpowering for too long. Your setup with a toggle switch should be reconsidered as it’s impossible to turn on and off in that timeframe.
 Second- You measured the resistance of the components but do you have the design specs for the coil??Measuring resistance will give you one of 3 outcomes. Either the resistance is within spec or too low or too high. If you measured the resistance and found it out of spec and to the low side, it could mean in the case of an ignition coil, that the winding is short circuited and if so, it will not build a full magnetic flux. It’s unlikely that you’ll ever measure a coil with high resistance. You might measure a primary winding with an open circuit but it would be a rare event. It would depend on where in the coil the winding burnt out.
Third- A condenser acts like an accumulator. It accepts a charge and will also dissipate a charge. In the case of a points operated ignition circuit, when the magnetic field collapses, it also collapses on the primary winding and creates a voltage on the primary side equal to 1 volt per winding. Most primary windings are in the neighborhood of 150-200 windings so the voltage created by the field collapsing can be around 150-200 volts. That voltage is absorbed by the condenser and then once the voltage in the primary windings drops below the 150-200 volts, the charged condenser offloads it’s charge into the primary circuit and that can extend the duration of the spark slightly, but the purpose is to discharge that energy before the points close and help reduce the electrical load across the points. Your setup less the condenser should create a spark although I would caution you not to toggle the switch too many times for fear of burning out the primary windings. I suspect a short in the primary windings are why your test is not working. Usually, a standard test for coils involves a setup similar to yours, but instead of using a switch, the positive wire end is momentarily tapped on the battery terminal which limits the “on time” to something more appropriate.
#32564
Thanks for the reply, Sir Bucko! Read your and KB's post, thought wooHoo this work!
Back at bench, removed the spark plug 'ground' lead from battery negative terminal. Removed rocker switch per KB comment below. Both spark plugs "grounded" together e.g. the thread area is connected via wire. Continuity proven via ohmmeter.
Tap coil positive to battery plus and ...and...and...Nada Zilch. Zero spark.
Now I'm really confused. Maybe KB is right, and I fried the coil?
Reconnect the condenser and voila, big blue hot spark.. Not sure where to go from here, LOL.
Last edit: 2 years 3 months ago by dcarver220b.
