Dynatek DDK2-18C
- f_schenk
Dynatek DDK2-18C
4 years 5 months ago
Anyone happen to have a Dynatek DDK2-18C
Ignition Kit that's sitting on a shelf not being used? If so I am a buyer for it.
- zed_thirteen
Re: Dynatek DDK2-18C
4 years 4 months ago
I bought a faulty one of eBay hoping to fix the problem output but removing the resin pulled component from the board and made it useless.
I know Dyna have to protect their design but I bought my Dyna ignition to extend the life of my Z13 and Dyna quickly stopped producing it and removed support. If it goes wrong now it's just tough
Don't be throwing in the towel yet. I haven't seen a circuit board that couldn't be repaired. It's specialty work yes, but somebody should be able to help you out.
- f_schenk
- zed_thirteen
I just can't find anything to shift the resin. I had been using a dremel to grind some away. You can see where two of the output transistors are lifted the resin pulled one of the resistors and some SMD capacitors.. There's a lot of green on the underside of the resin which could mostly be lacquer.
I need something that will dissolve the resin. Acetone isn't touching it
Time to create page: 0.223 seconds
