Overcharging? 15v at all rpm
  • stocktoy
  • stocktoy's Avatar
Re: Overcharging? 15v at all rpm
7 years 6 months ago
#23848
Princess Auto sells this type of fuse holder.
scotch wrote: can't add much ! kawboys suggestion of using 2 MOSFET's seems logical.
Answer to the P.M.: Copy and paste this to an ebay search
6 Way Fuse Holder Block 90V 115x53x42mm Car Vehicle Circuit Blade Fuse B MJW
Toss the fuses that come with this and buy some good quality ones at your auto-parts store ! !!
The over charging would suggest the regulator is shot !
#23851
There's certainly all sorts of shapes, sizes and configurations available. Best to FIRST determine how many circuits do you want? Then: where the fuse block can be located and how it can be secured? All the while keeping in mind the orientation (direction and position) of the terminals on the fuse block itself and the possibility that some of the leads may require lengthening to reach the new location.
And of course: Has to be easily accessible.
Under the right side cover was the obvious choice for myself.
Last edit: 7 years 6 months ago by scotch.
