KZ1300 A1. US Spec. Headlight Question.
Re: KZ1300 A1. US Spec. Headlight Question.
Thanks Scotch................but a simple single switch wired into the NEGATIVE side of the bulb is far easier than wiring for both High and Low circuits and prevents ALL power to either low or high beam, so covers both.
The switch will only be OFF for a matter of seconds when I initially start the bike, as I will want the lights on as soon as its running.
It does mean the WHITE BULB FAIL LIGHT on the right of the light cluster is illuminated by the control unit when the switch is OFF, but that's good as it also acts as a prompt for me to turn the switch back on when the bike is started..........so fail safe !
I've now carried this job out and it all works perfectly and allows all the battery power to go directly to the Starter instead of the headlight bulb stealing it !
Thanks again
Thanks again
Last edit: 7 years 9 months ago by strate6.
7 years 9 months agostocktoy wrote: What I did was to take the switch apart and file the rotating disk that the button is fastened to so the switch would rotate past the low beam position enough that the headlight would go off.
I also did this same mod years ago when my 79 was still 'new'.
7 years 9 months agostocktoy wrote: It is wired so the headlight is on all the time. What I did was to take the switch apart and file the rotating disk that the button is fastened to so the switch would rotate past the low beam position enough that the headlight would go off. Giving me the option to turn the headlight off if desired. However if you go to Electrical Connections website they sell a headlight bypass relay for the Honda Goldwing ( I have an 06 model among others...:woohoo: ) so the headlight will not turn on until the relay is energized after starting. I'm sure it could be incorporated into the 1300's headlight circuit.
electricalconnection.com/index.php/brand...da/goldwing-tour-18/
Which "Switch" are you refering to ?
Thanks
electricalconnection.com/?s=headlight+relay
Hope this helps
