HEI ignition?
  • Mikez
  • Mikez's Avatar Topic Author
HEI ignition?
12 years 10 months ago
#666
When I bought my bike this year I had wondered what those black modules were. I had assumed they were additional resistors because the bike has GM coils on it. The modules are mounted to an aluminum plate behind one of my side covers.
I just figured out through random browsing today that they're HEI ignition modules. If I have those then I must not have an igniter anywhere :(.
My question now is will I be able to complete an AW-82TRI coil conversion with those in there? I certainly wont be able to find an igniter anywhere much less pay for one so my options are slim. The modules don't appear to have anything protecting them from the elements either just exposed connections and such. I'll take some pics tonight of the setup and post them up tomorrow but any additional info would be awesome lol.
If it helps, one of the prior owners of my bike was this person: www.kzrider.com/component/joomgallery/kz...ing-kong-lives1-6699
Thanks!
Re: HEI ignition?
#670
Not sure what you mean by HEi Ignition.
Can you possibly post a pic of them.
What year & model is your 1300 ?
Re: HEI ignition?
#671
OK, just had a look at a pic of your bike & its an A1 or A2 model (ignition unit above clutch casing)
Very interested to se images of these "modules"
  • Mikez
Re: HEI ignition?
12 years 10 months ago - 12 years 10 months ago
#702
My bike is a 1980 A model. The aluminum plate that these were mounted to were mounted to the right hand side of the bike behind the cover.
Sorry, I wasn't able to get any work done on my bike this weekend my wife&kids kept me busy lol. I can post links and pictures of the modules themselves. HEI generally stands for High energy ignition and from what I can tell a good setup can make a good replacement for an igniter and replaces points. I've done a bit of browsing and most of the data I could find came from kzrider.com's forums.
We should probably link to a writeup here in case there's anyone out there with a broken ingiter lol.
home.comcast.net/~loudgpz/GPZweb/Ignitio...heiModForPoints.html
www.kzrider.com/forum/4-electrical/35560...l=component&type=raw
www.kzrider.com/forum/2-engine/376865-cs...l=component&type=raw
www.kzrider.com/forum/4-electrical/36877...nt&type=raw&start=20
en.wikipedia.org/wiki/High_energy_ignition
www.kzrider.com/forum/4-electrical/31212...l=component&type=raw
www.kzrider.com/forum/4-electrical/33630...l=component&type=raw
Last edit: 12 years 10 months ago by Mikez.
Re: HEI ignition?
#703
By what I can see, these additional components must only be used with the GM Coil Pack someone has fitted already. I am sure they have a purpose, but you dont need them to do the AW82 coil conversion.
I am assuming you have the round ignition pick up module on the RH side of the bike behind the cylinder block ? The wiring from this goes to the CDI unit.
If you want to fit the AW82 Coils, then all you need is the 4 wires coming out of the harness next to the coils behind the head stock (BLACK/GREEN/BLUE/YELLOW)
Next check the wiring to the CDI Unit has not been altered or changed.
Any other parts added for the GM coils should be discarded.
The ignition system on the 1300A1 + A2 is simplicity in itself & has very little wiring in the first place so you cannot really go wrong.
Compare what you have to what is shown in the K manual. The BALLAST RESISTER which lives up on the LH side of the frame near the headstock also needs to be discarded. This is mentioned in the AW82 coil upgrade instructions I posted.
Let us know how you get on !!!
  • Mikez
Re: HEI ignition?
#704
Thanks Pete!
Yes my pickups are on the right hand side. Going to double check on all the wiring when I get home too.
As far as I can tell, the ingiter and coils were only replaced and the ballast is still in use. Rewiring it all should be simple once I get what I need in the mail.
