Lifting and Jacking with motorCycle jack
- jftman
1 year 9 months ago - 1 year 9 months ago
I know the center stand will get the front and rear tires off the ground with a little ingenuity.
I decided this year to give the tires a rest, and bought motorcycle jacks for each of my 3 motorcycles.
i can not find info in the manual and looking under the bike and looking at the jack, Ummmmmmm?
A small bit of frame tubes are there and there is some piece going across that is a little lower too.
Can I get something in combination with the jack? Or maybe lift it just right with no adapter?
Neither tire will be taken off, just here in NY it is winter weather I am facing.
Last edit: 1 year 9 months ago by jftman. Reason: Spelling
Re: Lifting and Jacking with motorCycle jack
1 year 8 months ago
On page 121 of the factory repair manual, the section dealing with removal of the front wheel shows a jacking point on the underside of the engine.
- jftman
1 year 8 months ago
How will the traditional motorcycle lift jack be used to zero in on this little round reinforced point? My jack has the two 1 foot wide slats and a handle to pump the unit up.
1 year 8 months ago
I wouldn't be lifting the motorcycle off the ground using the engine casing as a point of lift. The reference in the manual for removing the front wheel notes raising the front of the bike by placing a jack under the engine but the amount of pressure on the engine when doing this is minimal. Lifting the entire bike off the ground and using the engine casing as a support point would be a terrible idea.
I would consider fabbing up a jig to sit on your bike lift that lifted the bike using the 2 lower frame tubes that the center stand is attached to. That way you're lifting the bike from the same frame points that the center stand was designed for.
1 year 7 months ago
I made mine and it works beautifully. Easy to use and solid. My Nickel Plated Balls
stay on the forks !
It started it's life originally as a cheap (light-duty) hand cart. Cut-out what I needed and welded it up as you see it.
The following user(s) said Thank You: zed_thirteen, stocktoy
- jftman
1 year 7 months ago
ThankYou for the clarity and a suggestion to use a gig fir the frame tubes.
i really thought more owners would have made an adapter and showed them here.
