1979 Carb Rebuild (Pt 1)
- Tyler
Re: 1979 Carb Rebuild (Pt 1)
10 years 2 months ago
Nice work.
Using an ultrasonic cleaner is by far the easiest method. I did mine in a bath with "purple power" degreaser. Similar to simple green but not as caustic on aluminum and brass.
Before:
After disassembly and a dip in the cleaner for a couple hours.
I bought a used ultrasonic unit off of eBay for around $30, but the shipping cost close to $70 because of its weight. Even the cheap Chinese ones can do wonders. You don't have to buy special solution, any number of common cleaning chemicals work.
Before:
1981 KZ1300
That's very interesting, Tyler. I've often wondered if I should buy an ultrasonic cleaner, and now you have convinced me!
- Craig
Yes, I had the parts yellow passivated. Finishes them off beautifully.
Last edit: 10 years 2 months ago by Craig. Reason: spell
- homer01
This is what mine came up like after having one vapour blasted or water blasted as I think it was called
This is the bowls and caps I polished on sunday arvo
Last edit: 10 years 2 months ago by homer01.
- Away
10 years 2 months agoNice job there Mister. Probably Vapor blasted, (CO2 pellets that vaporize on contact). Did you get the O-rings in yet?
- homer01
Yes that's it guys vapour blasting, O-rings not in yet Kawaboy been getting everything re zinced to make them look pretty
