1979 Carb Rebuild (Pt 1)
Re: Complete rebuild 1979 carburettors (Photo Heavy)
10 years 6 months ago
AWESOME post. This one will be linked over at the
Candy Butt
website!
The idea of using a drill press with downward pressure is a great idea. Thanks again for posting!
- aus_z1300
10 years 6 months ago - 10 years 6 months ago
Great wite up love the use of the drill press they are so useful I use mine like a lathe occasionally and have also seen them used to bleed hydraulic lifters .
Last edit: 10 years 6 months ago by aus_z1300.
Re: Carb rebuild continues with some cautionary notes.
The carbs have been thoroughly cleaned now. Starting with a preliminary boiling (5 to 1 lemon-juice)for a full day which removed most of the grease, oil and some light varnish and scaling. The body, bowl and top-cover were then glass-bead cleaned (I have a blasting cabinet); with one exception. I DID NOT glass-bead the throttle-bores!
The throttle-plates are precision ground to fit the venturi tightly when closed. Any attempt to clean the venturi or the throttle-plates by glass-bead cleaning would ruin them by destroying the ground edge of the throttle-plates. This would make tuning and sync'ing all but impossible. The varnish was removed from the venturis and plates with a small paint brush,lacquer-thinner and a light rubbing with "Scotch-Brite". For similar reasons the slide-bores and needle-pistons were left alone with only a cleaning using lacquer-thinner and a soft cloth.
Also note the last pictures regarding the choke pick-up tube. I was lucky in finding the jet when it blew out under air-pressure cleaning. A heavy towel on my work-bench caught it and saved me a lot of additional work! I suspect the tiny split may have been from years of stress from the jet being pressed into the end. This jet is critical! Without it there is no metered flow of fuel to and through the choke passages.
The final check to assure clear-flow through all the passage ways will be done with lacquer-thinner (to dissolve and flush anything remaining in the galleries) using the syringe you saw in the previous pictures. Once confirmed flowing and clean the final polishing and painting can take place.
The Philips-heads of 2 of the carb-bowl drain-screws were in rough shape and I dislike Philips-heads anyway, so I silver-soldered a socket-head onto them. The idle-air screws will receive a similar treatment.
Last edit: 10 years 6 months ago by scotch.
The following user(s) said Thank You: zed_thirteen, Kawboy, PaulD
Awesome work you're doing here. Really impressed and thank you for documenting your rebuild with such dedication . Love the pics with all the critical notations. You're obviously a master and I will be pulling up this thread when I rebuild my carbs. I have a basket case that I bought 10 years ago and moved houses 5 times. Now I'm getting in to the rebuild.
Again, Thanks for posting the thread!!
Yeah, absolutely pro - this is carburettor-porn, in any positive way, thanks for posting it.
