IDLE AND FLOODING/CHOKE ISSUE
  • SIXPIPES
  • SIXPIPES's Avatar Topic Author
Re: IDLE AND FLOODING/CHOKE ISSUE
11 years 11 months ago
#4981
Hello Bill,
I can get it to run at 2,500 rpm on the throttle or using the throttle stop screw ( the main one under the carbs) if I use the main throttle stop then it takes an age for the revs to come down should I rev it.
  • Toddh
  • Toddh's Avatar
#4984
SIXPIPES wrote: Hello Bill,
Say Andy:
If it "Takes an Age" for the revs to come down, this suggests a couple of potential problems or both.
1: Its possible you have a vacuum leak, check the intake boots, Air injection system, vacuum nipples on the in take on the head.
2: Your balance adjusters (place where you synchronize the carbs) may be way out of adjustment. Shouldn't be more than 4 turns out, if memory serves me correctly.
3: read the manual on setting the base idle screw. All settings are based on where you have that throttle and fast idle set at.
Let us know.
Todd.
Last edit: 11 years 11 months ago by Toddh.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
#4986
I'm with Todd! Sounds like a vacuum leak.
