Correct Fuel Line Routing
Re: Correct Fuel Line Routing
12 years 7 months agozed_thirteen wrote: Very helpful Pete.
I fitted a brand new pingel fuel tap and it still leaks fuel when it is off. Might look for one of those GPZ900R fuel taps
That's too bad and very strange. I can think of a few things around my house that I wish would shut off as cleanly as the Pingle I fitted to my 13.
Good Luck
- kwak1261
KZQ spot on,
I have pingle taps on my Z1260J and my GS1000S and never had a problem
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
Z1261J GS1000S
Vmax1200 XT500
Pingle taps are normally spot on & a quality product.
The only problem is............if you forget to turn them off, you then risk flooding your engine.
This is impossible with the GPZ900 tap........which is why I fitted it.
My memory aint as good as it used to be !
When the 13 came out it had an electric solenoid fuel shut off valve
Last edit: 12 years 7 months ago by kza13. Reason: i was wrong again
- KEL
I just looked at mine and it is mounted to the frame ABOVE the carbs.
(see the picture. its the small box thingy)
Aftermarket??
Aftermarket??
Last edit: 12 years 7 months ago by KEL.
12 years 7 months ago - 11 years 5 months ago
reference material out dated and no longer relevant
Last edit: 11 years 5 months ago by scotch.
