ENGINE STUTTERING AND MISSING AT LOW REVS
  • stocktoy
  • stocktoy's Avatar
Re: ENGINE STUTTERING AND MISSING AT LOW REVS
9 years 6 months ago
#16184
interesting link here (maybe?) Sta-bil
  • Away
#16193
Here's another link to a 2 page article put out by Echo Small Engines discussing the issues related to Ethanol Blended fuels, the consequences of buying and or using old fuel along with pics showing the damage caused by phase separation in the fuel once allowed to sit in the carbs. It's a great 5 minute read if you've not made yourself aware of the issues around Ethanol.
www.echo.ca/Warranty/Learn-About-Ethanol/Ethanol-Fuel-062512
Last edit: 9 years 6 months ago by Kawboy.
The following user(s) said Thank You: stocktoy, southpaw, LareNurminen, Ledkz1300
  • usakz1300
  • usakz1300's Avatar
9 years 5 months ago
#16299
Yes, those epoxy filled coils do split the outer jackets from excessive heat that the epoxy does not let transfer out of the coil. The me4sh is the final cover before the outer jacket. One other thing to test in the coils packs is the resistance of each spark plug cap. Higher resistance is bad, will also help cause higher coil core temps, and help to fail the coils. To test, unscrew the cap off the wire, test with ohms meter, on Rx1k scale, should be no more than 5K ohms. Look on the cap, there might be a number on the body, like LB05F, 5.0 ohms would be the resistance value to have.
Also, in addition to the jets and passages info already given, which is excellent, carb rubber manifold to head sealing is critical, best to use Three-Bond 1194 case sealer between manifolds and head.
Hope this helps.
  • Haggler
  • Haggler's Avatar
#16327
You need to zoom in on the first pic around the 1-2 o'clock area to see perforations. The second pic is just stock wear and tear I think
[IMG
[IMG
  • kiwirider
  • kiwirider's Avatar
9 years 1 month ago
#17203
Hi jabee i have the some fault with my bike did you fix yours and what was the fault please thanks Graham
