Weeping Water Pump and other opportunities.
3 weeks 5 days ago - 3 weeks 5 days ago
Hi Folks,
I recently put my 81 KZ 1300 on the lift to adjust the valves. They were no big issue, the bike has only 7,000 miles on it. As I was putting the engine through a complete heat cycle, before I took it off the lift, it started weeping from the drain at the center front of the engine.
Unfortunately, I've been here before. Soon after I actually started riding this bike, years ago, it developed original leak. Which I repaired, perhaps in-artfully.
At that time I noted that the water pump shaft was pretty well corroded, right up to the very lip of the oil seal. I replaced that seal and the mechanical seal as well but had my doubts about the whole effort because of the corrosion on the water pump shaft.
Any way : Here I go again.
I've purchased a water pump shaft but need to put together a complete lift of the gaskets and O rings I'll need. In addition to what ever machine work I'll need done. (I don't think my radial arm saw's up to it.)
Is a base gasket necessarily part of removing and reinstalling the head?
That'll be my first question.
The other opportunities include a steel idler gear. The nylon gear in this one shows significant wear.
TIA
TIA
Last edit: 3 weeks 5 days ago by KZQ.
- tackelhappy
Re: Weeping Water Pump and other opportunities.
3 weeks 5 days ago
You'll need a new head casket if you are replacing the cam chain idler gear with -say -- a Liska. The head has to come off. But the engine block doesn't need to be removed for either the gear replacement or the water shaft and seal . So you don't need a base casket .
As a note . I used Cruisin Image big bore kit, pistons, rings and his gasket set probably 13 years ago . Still working as it should.
I bought two gasket sets from them about a month ago . Paid by Paypal on the Monday - had them by Friday . -shipped from Japan
3 days 3 hours ago
Thanks Tackelhappy,
That's quite a site. The quoted prices are very reasonable with one unknown, "Tax Not Included". I awaiting a verification e-mail set up an account.
Complete ring set $70.00
Complete big bore kit with a head gasket $250.00
I'd be a kid in a candy store if I could be sure of today's quality. What did you think of the head gaskets you ordered?
Thanks for the link.
- tackelhappy
2 days 19 hours agoThis the gasket set . If one of the more knowledgeable members could look at the head gasket and give some appraisal of it -- I could open the packaging and take better photo's . I can understand the risk factor in using poor gaskets. It's a big job to put your engine back together -- then have to redo it all.
Let me know if better photo's would help .
The following user(s) said Thank You: KZQ, Kawboy
1 day 3 hours ago - 1 day 45 minutes ago
That head gasket is typical for "After-Market" - No Sealant material around the coolant ports (required on both sides, in my opinion and experience). As is, the risk of it leaking is significant. I have not used anything like Yama-bond (not an endorsement) but others claim they have, with success.
What I do notice with this head gasket is the smooth material surface. "Italianmetals" and "Athena" have a ridiculously heavy "embossed" pattern on both sides which are nothing more than galleries for the coolant to leak from.
Last edit: 1 day 45 minutes ago by scotch.
2 hours 35 minutes ago - 2 hours 17 minutes ago
I wonder what that string looking stuff is in the bottom right, on top of the valve seals.
I followed D&K Gaskets to Matto Gaskets
www.engine-gasket.com/
I sent Matto an e-mail asking if they dabble with 1300s.
Last edit: 2 hours 17 minutes ago by KZQ.
Time to create page: 0.091 seconds
