rear-brake, tech-advise needed 2 years 10 months ago #29189
  • BigSix
  • Thank you received: 221
Hi Guys,
I took the lady out of her slumber and she, after getting fuel started fine. I though noticed at a crossing that she, even with neutral in, does not roll anymore any noticed the rear-brake blocking. The disc hot, so I paused and made it home. With help from a friend we dismounted the rear-master cylinder and noticed the piston was stuck. We have been able to get him moving again, yet the brake shows the identical symptoms, after around 1 mile the disc is hot. Compare to the front-discs too hot I guess.
What would be your approach ?
Thanks and best regards,
rear-brake, tech-advise needed 2 years 10 months ago #29190
  • Thank you received: 164
The equalizing port (smaller of the two holes) in your master cylinder is blocked and preventing brake fluid from flowing back into the reservoir when you release the brakes. Use a small wire or toothpick to clear the blockage and flush the fluid.
rear-brake, tech-advise needed 2 years 10 months ago #29191
  • BigSix
Hey Bucko, thanks. When we dismounted the master-cylinder, we did check if that hole is clean since that was the first idea. It was clean indeed, and at the same time I was able to press one of the pistons back into the caliper. I just ordered myself the below item to see if that will solve it:
Keep your fingers crossed ...
ebay 172807438951
Last edit: by BigSix. Reason: looked bad
rear-brake, tech-advise needed 2 years 10 months ago #29195
  • Neville
  • Neville's Avatar
  • Thank you received: 75
I had the same rear brake problem a number of years ago - however, it was my fault as I adjusted the pedal stop to reduce the free play.  Not logical for this to happen if you had no problems last time you ran your 1300 but worth checking?
rear-brake, tech-advise needed 2 years 10 months ago #29197
  • BigSix
Will check that, though I did not change anything in there.
rear-brake, tech-advise needed 2 years 10 months ago #29198
  • zed_thirteen
  • zed_thirteen's Avatar
  • Thank you received: 137
I agree - I've done this too.  Noticed an orange glowing rear disk when passing a motorcycle shop window
