me again, the front master cylinder which was rebuilt with a new piston asst is ok BUT it only grabs when the brake lever is almost at the handlebar, but brake seems ok, bike in lift, Ive only bled from top down, do you think bleeding from bottom up would make a difference
But the rear master cyl which was leaking before winter leaked after I put the good front mc seal on it, just the front one as its easy to change, So tonight I heated the rear piston in oil to 120C and easily removed the second seal and also the seal from the good front brake and put it on. Has anyone done this previously? If it wont hold px I';ll have to spend the big bucks fir the rear kit
