Sure. Of course bushing shells removed.
Outside distance 147.35 mm, inside 94.05. Short arm diameter 14.8 mm, big end diameter 38.75. Just in case the wrist pin 15 mm.
For the record, my crankshaft main bearings show 40 mm. Of course the calipers (not digital) will not indicate below 0.01 mm, so accordingly these measurements are as close as I can read them on a manual caliper, and that's for one random connecting rod. (Still hunting for a 1" - 2" micrometer on eBay!)
It adds up to 120.7 mm. Pretty close to 120! I hear 'you have a good eye Stan!' hahaha
One other little update - I tightened the bolt and nut by hand, not to the required by manual torque. That would take off the measurements as well. I'd safely assume that it is actually 120 mm. It's also a nice round number. Just like with the pins at 15 mm, I'd think a designer would choose this rather than fiddling with tenths or hundreds of a millimeter.
