Modern fuel injection system for a 1300. 10 years 2 months ago #1472
  • KZQ
  • KZQ's Avatar Topic Author
  • Administrator
  • Administrator
  • Thank you received: 274
There's been some interest of late here about converting a 1300 either from a carb model to fuel injection or just getting rid of the DFI that was used on these bikes in the 80's. I found a thread over at KZRider that might yield some good information:
www.kzrider.com/forum/4-electrical/47357...irt-microsquirt-a-kz
From there I found a link to Do It Yourself Autotune where they sell microsquirt systems designed just for bikes:
www.diyautotune.com/catalog/microsquirt-...26b1d9a5c672b65b0329
Regards
Modern fuel injection system for a 1300. 10 years 2 months ago #1473
  • RickG
  • RickG's Avatar
  • Thank you received: 95
Thanks for that link Bill it makes my project a bit easier.
I may even get a start on the hands on bit later this year
Modern fuel injection system for a 1300. 10 years 2 months ago #1505
  • Toddh
  • Toddh's Avatar
  • Thank you received: 65
I emailed DIYAUTOTUNE a list of questions specific to our bikes. When and if they reply, I'll share that with the clan.
Todd.
Modern fuel injection system for a 1300. 10 years 1 month ago #1872
  • Lincolnman
  • Lincolnman's Avatar
  • Thank you received: 0
The Microsquirt is only for 4 cylinder machines or less. It could be made to work on the six but would have to be batch fire in two sets of three I think. I am pretty sure that it would not do three sets of two.
I was looking into converting my 1979 over to fuel injection because we cannot get the carbs to come apart properly. If I am going to drill them anyway I am going to convert them to injection.
I was going to use the MS3 PRO because I can get caught in the rain and I will be more concerned for the rest of the bike than the EFI. I already have an MS3 setup that I have been tinkering with on a V12 so I am fairly confident about making it work on the Kawasaki.
I got here by Googling KZ1300 fuel injection looking to get information on the injectors used on the later models. Anyone have any idea what the specs where on those?
Electronics work on magic smoke, do not let it out.
Modern fuel injection system for a 1300. 10 years 1 month ago #1877
  • Mikez
  • Mikez's Avatar
  • Thank you received: 14
You might find more data using ZN1300 and Voyager in your search terms. There's another forum I found this week specifically for voyager owners you could try looking around there too :).
www.amervoyassoc.org/forum
I haven't gone through their forums in detail yet but hey whatever it's worth a shot!
Modern fuel injection system for a 1300. 10 years 1 month ago #1880
  • Toddh
  • Toddh's Avatar
The Thread below is some back and forth I had with Matt at DIYAUTOTUNE. Being this is an email thread, you will want to start at the bottom and work your way up.
Matt at DIY seemed to think the larger system could accommodate Batch injection for three channels. Due to the 1300 having wasted spark. I think only three of the 4 channels would be needed. To jump to Sequential injection, Then a Crank and Cam sensor would need to be added.
I have seen posts on the Crank portion, but not on the Cam wheel. Matt at DIA had some good ideas and they have added a CAM sensor to an OHC bike in the past.
See post below.
"Hello Todd,
The Hall sensor setup can be considered a kind of crank angle sensor; the downside is, the MS2 doesn't support three separate crank sensors (two can be done, but it doesn't have enough I/O for three of them). You could replace the single tooth wheel on one sensor with something like a Ford style 36-1 pattern to control ignition.
As for sequential injection: You could drill the cam cover and use a Hall sensor to read a cam lobe or other protrusion on the cam sensor. We did that for our land speed racing car when the cam was missing a distributor gear (it was meant for a different cylinder head).
Let me know if this sounds doable.
Matt Cramer
DIYAutoTune.com support
On 2014-01-29 13:35, Toddh wrote:
> Hello Matt:
> Thanks for your initial response.
> I am wanting to eliminate my carbs on an engine that never had any
> electronic trigger mechanisms on the crank or cam, other than the
> three Hall triggers on the crank. No crank angle sensor (Wheel) per
> say (or
> reluctor)
> Just the triggers for the low voltage side of the ign.
> So with that said, can I just tap into the three hall sensors for a
> signal, or do I need to add a reluctor wheel and add a different
> pick-up?
> I would very much like to get to Sequential F.I. but being this engine
> does not have the needed CAM sensor, have you seen anyone add that
> feature to an
> engine never engineered with said pick-up. Like you state, the idle
> and
> throttle would be much better.
> With a wasted spark Ign, would I only need the three channels on this
> 6 cyl
> bike? (I assume that is the case)
> **In a snapshot, if the crank angle sensor and cam sensor is too
> difficult to add, then I would probably focus on the Micro S.
> (depending on if I can
> keep my existing pick up coils) and if I can run a 6 Cyl engine on
> it.
> **Or if Sequential is doable, I would need to determine how to add the
> crank and cam reference points. (Sensors)
> As carburetors go, my current set are very inefficient at idle, even
> at a highly tuned and clean state. If I run Batch Injection, I wonder
> if my mixture would be just as inefficient?
> If I understand you statement below, I don't think running two
> channels would suffice. My firing is grouped into three segments,
> 1-6, 2-5, 3-4.
> Based on this firing order, would I need the larger module?
> What think ye?
> Todd."
Original Message
> From: DIYAutoTune.com Sales (Matt) [This email address is being protected from spambots. You need JavaScript enabled to view it.]
> Sent: Wednesday, January 29, 2014 9:31 AM
> To: Todd Hurt
> Subject: Re: Contact from DIYAutoTune.com: Technical: 6 cylinder
> kawasaki application
> Hello Todd,
> The MicroSquirt has two injector channels available, but they could
> each run three injectors. There's no reason you can't run batch
> injection here.
> Sequential injection gives better idle quality and light throttle
> drivablity, but peak power is generally the same unless you want to
> use individual cylinder tuning.. Running sequential injection would
> require an MS3, or an MS3-Pro if you want a similar design to the
> MIcroSquirt.
> The MicroSquirt is not expandable.
> For ignition, you could have the ECU control just fuel, or you could
> add a crank trigger if you want to control fuel and the existing
> trigger wheel turns out to be incompatible. Do you have any
> information about the existing ignition trigger?
> Thanks,
> Matt Cramer
> DIYAutoTune.com Support
> Please include the previous messages in your reply. This will help me
> look up our conversation and get back to you sooner.
> On 1/28/2014 1:43 PM, Todd Hurt wrote:
>> Technical: 6 cylinder kawasaki application
>> Hello:
>> Over the years, I have read about the M.Squirt product and was
>> wondering if my KZ1300 (6 cylinder) bike would be a candidate for
>> this system?
>> 1: Are there 6 injector channels available. Is the Micro Squirt able
>> to accommodate this or do I have to go to the Mega Squirt?
>> 2: Can I get by with just a Batch Injection set up?
>> 3: My bike does not have a crank angle sensor, is there a board or
>> way via RPM to address this?
>> 4: Secondary Ignition wise, can I use my existing high voltage coils
>> and does the daughter board have 6 channels. My system is a wasted
>> spark system and it only has three coils to begin with so the 4
>> channel board may suffice.
>> 5: For sequential applications, would there be a way to add that
>> feature now or down the road to go from batch to sequential?
>> 6: If this system would work, a rough bill of materials and cost?
>> Regards.
>> Todd.
Last edit: by Toddh.
Time to create page: 0.144 seconds
