fuel tee o-rings 8 years 10 months ago #7582
  • bassie20
  • bassie20's Avatar Topic Author
  • Thank you received: 6
I'm cleaning/rebuilding my '79 carbs
I need new o-rings for the fuel tee and the cross over piece..
are they the same as vm26-28 carb fuel tee o-rings, or any one know were to order the correct ones?
fuel tee o-rings 8 years 10 months ago #7587
  • kwak1261
  • kwak1261's Avatar
  • Thank you received: 72
Hi
not sure what part of the world your in but these people in the UK are very helpfull
www.allensperformance.co.uk/products-mikuni%20carbs.html
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
fuel tee o-rings 8 years 10 months ago #7592
  • Thank you received: 1029
Better look at your tees again. If they're the same as my 1980 the oring "bumps" are actually part of the tee (molded in).
Just checked Partszilla and there's no item specifically for the "oring" you think you need.
fuel tee o-rings 8 years 10 months ago #7600
  • bassie20
hm, yes looks like they are molded in..
I didn't have a leak before so I guess i'm just going to use them as is, but the outer ones are a little flat though..
maybe someone knows a tee and pipe with replaceble o-rings that fits?
fuel tee o-rings 8 years 10 months ago #7601
  • bassie20
think I found it!!
they also have the cross over pipe from anothor carb but it's to short, but I can make it longer myself wit a little tig welding
fuel tee o-rings 8 years 10 months ago #7602
Tell you what I'd be doing. buy two of these tees and either set up a dual feed or just cap off the one tee.
By the way, what are those tees spec'd out for (which Yamaha) I just might pick them up myself.
Thanks
Kawboy
Post Script editing
Check this out. I'll be pulling the tees and crossover fitting from my carbs and measuring up for these.
Search EBay for this "Kawasaki Carb Crossover Fitting /Aluminum KZ1000 Kz650"
and this " Kawasaki Carb Fuel Tee,Pipe /Alum Z1,Kz900, Kz1000 '73-'81 " (can't get the http link to go in)
Last edit: by Kawboy.
Time to create page: 0.113 seconds
