Another basket case project, but with potentially a different end goal! 4 years 1 month ago #25995
  • Thank you received: 1028
Progress. Nice !!
Another basket case project, but with potentially a different end goal! 4 years 1 month ago #25999
  • User is blocked
  • User is blocked
  • Thank you received: 248
Looks good Paul!
0ne thing I'd suggest and it would potentially make things easier, but it's not a 'must'. If you remove the swig arm (it should be easy as all is fresh now and be just a 5 minutes job), it will be much easier to attach the drive shaft, especially that with the swing arm installed you will have the rubber boot in a way. Plus, no access to the torque wrench with the boot there. I'd install the engine, then the shaft, slip on the boot and then the swing arm.
Another basket case project, but with potentially a different end goal! 4 years 1 month ago #26003
  • McBoney
  • Thank you received: 96
Yeah, I did think of that, but I have no way to install the engine without wheels... and even if I could, the whole lump becomes pretty unmanageable.
I have a plan for accessing the bolts with the rubber boot in place... an extra pair of hands! ;-)
Another basket case project, but with potentially a different end goal! 4 years 1 month ago #26074
  • McBoney
Its been a while since any progress has been made.
My tyres have still not arrived, but finally I have had the drawing of my top yoke back. The guy (I found him on peopleperhour) did a fantastic job of interpreting my rough drawings with measurements into a proper tech drawing. Based on that he also created a 3D CAD file which can now be used to mill a block of aluminum (or steel) to create my bespoke top yoke. Benelli front suspension and bottom yoke married to a bespoke top yoke through the original Kawasaki steering pin.
Once I have the yoke and the wheels I can progress the build again...
Last edit: by McBoney.
Another basket case project, but with potentially a different end goal! 4 years 1 month ago #26138
  • McBoney
Ugh! Cheapest quote to get this machined was USD380 from a firm in China. Cheapest UK quote was over £400!
That is NOT in the budget, so now going to experiment with existing yokes. I have got a cheap one from an MV Agusta 750 which looks likely to fit with minimal work.
In the meantime my new rear tyre turned up (front still not in stock). I got it mounted and balanced (and annoyed as they chipped my new powder coat!) and got it onto the bike. This is a Bridgestone Battlax BT45, 150mm wide, and if you look at the pics, these fit the swingarm fine with at least 1-2cm clearance.
Once the front tyre arrives and I have sorted the triple tree conundrum (see other thread), the engine can go back into the frame and then it will start looking like a bike again.
Another basket case project, but with potentially a different end goal! 4 years 1 month ago #26139
  • Thank you received: 831
Having had the Cleaning Tool prototype and a one-of '"Spin-on Oil-Filter Adapter/Cooler" done CNC - THAT'S CHEAP !
Time to create page: 0.115 seconds
