Replacement carb slide diaphragms 7 years 2 months ago #15544
  • zed_thirteen
  • zed_thirteen's Avatar Topic Author
  • Thank you received: 137
Anybody able to comment on the quality and successfulness of these carb slide diaphragms? eBay item 112233366478
I think one of mine has a tiny hole near the outer edge and might change them while I have them off for cleaning.
Replacement carb slide diaphragms 7 years 2 months ago #15571
  • Thank you received: 1029
zed_thirteen wrote: Anybody able to comment on the quality and successfulness of these carb slide diaphragms? eBay item 112233366478
I can't believe no one's replied after 2 days. Surely someone has gone and bought new diaphragms. ????
Replacement carb slide diaphragms 7 years 2 months ago #15572
  • McZed
  • McZed's Avatar
  • Thank you received: 26
I think that's about the only thing I haven't had to replace on my big Zed.
Z1300 UK
Replacement carb slide diaphragms 7 years 2 months ago #15576
  • LareNurminen
  • LareNurminen's Avatar
  • Thank you received: 162
The word from the Finnish 1300 riders is that the replacement ones tend to be stiffer than originals. This can cause problems when riding since the carbs do not react as soon as they should. I have always kept the original ones when repairing carbs.
Replacement carb slide diaphragms 7 years 2 months ago #15577
  • Raygun
  • Raygun's Avatar
  • Thank you received: 17
If its just a small hole, I would just try to repair it on the top with silicon or something.
1982 KZ1300
2003 KLX400SR
1999 KDX220
Wife
Son
Daughter
Cat x 3
Replacement carb slide diaphragms 7 years 2 months ago #15578
Raygun wrote: If its just a small hole, I would just try to repair it on the top with silicon or something.
Locitie used to make a product called Black Max. It was a glue compound similar to Superglue or Carzy Glue but when it set up it was still elastic. At the nuclear plant we used to make our orings from bulk oring material, cut the ends square and glue them toether with the Black Max. 5 minutes later, you could install. I would think the Black Max would be the ticket for repairing a cracked diaphragm.
Here's a link to the loctite oring kit and if interested you can read and see how it''s done with the Loctite 406.
www.loctite.com.au/3320_AUE_HTML.htm?nodeid=8802647080961
Last edit: by Kawboy. Reason: add a link
