Medlock1 wrote: Be careful of the seven hex rotor bolts, four came out fairly easily, the other three would not budge. I had used a new / sharp 6mm bit. Had to grind off the heads flush to the rotor (carefully)and was able to remove the last three with a pair of vice grips. Each of the three had corrosion underneath.
This is a great time to discuss the use of "Copper Anti-Seize" on certain nuts and bolts on motorcycles.
Copper Anti-Seize prevents dis-similar metal corrosion and for those fasteners that are directly exposed to the elements (Road Spray) for the next time they have to be removed.
Works great for spark plugs too.
Regards.
Todd.
