Water Pump Puller
  • Tyler
  • Tyler's Avatar Topic Author
Water Pump Puller
10 years 6 months ago - 10 years 6 months ago
#5005
Getting ready to send my cylinder block to the machinist, and I had been procrastinating about how to remove the water pump without messing anything up. I tired at first with some locking pliers and couldn't get the impeller to move, I was afraid I would break it that way.
I made this puller using some 1/8 inch cold-rolled steel rod. It was just strong enough to remove the impeller. I don't know what the dealers used to do this work, was there a factory tool to pull these apart?
this was not an easy task. I had to tighten the bolt up until the arms started to bend and then tap the bolt to slide the impeller out about .010" at a time. If I tried to reposition the puller, the o-ring on the shaft would pull the impeller back and I would loose my progress.
It did come apart without damage to the impeller or the housing.
1981 KZ1300
Last edit: 10 years 6 months ago by Tyler.
The following user(s) said Thank You: Bob4717, zed_thirteen
  • tackelhappy
  • tackelhappy's Avatar
Re: Water Pump Puller
#5008
Well, good for you - it all worked out . They never come apart easy. I used a small upholstery hammer and taped shaft and impeller out from the other end as one piece , then lots of soaking in wd40 for several days.
While waiting on the parts soaking I checked both Ron Ayers and Kawasaki Parts Nation and both sellers had these parts available -but now they don't- or at least not on their web sites.
It was good you could salvage the parts you had
  • Tyler
#5009
I though the seal housing had to come off in order to get the shaft out? Looking at it again it appears not... so I could have pulled the impeller off with the shaft... now I feel dumb :blush:
I would not want to do this job with the engine in the bike, that would be no fun at all...
1981 KZ1300
The following user(s) said Thank You: charlie9670
  • Phil
  • Phil's Avatar
  • 1984 ZG1300-A1 DFI
#5010
That puller is ideal! :) And you're right, that job isn't fun with the engine installed.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
#5011
Nicely done Tyler! The rest of us have learned something. That's quite a contribution to the site.
