Cam Chain Adjustment Procedure?
- KEL
Did a search here but nothing showed up.
By the looks of things I have a manual Cam Chain adjuster fitted.
My motor is making chainy chattering sounds so may need adjusting.
What's is the "Dummies Guide" to doing this?
Thanks in advance.
Thanks in advance.
Last edit: 12 years 5 months ago by KEL.
- Toddh
Re: Cam Chain Adjustment Procedure?
I used to adjust manual camchain tensioners by:
1: With the engine running, back off the lock nut while holding the outer nut adjuster.
2: Turn in the outer adjuster (Slowly) until you hear the clatter noise go away.
3: Once the noise goes away, back the outer adjuster out 1/4 turn, and while holding the outer adjuster, tighten the lock nut down.
By backing it out slightly you should be providing enough slack in the chain to run quiet enough but provide enough tension to keep the chain relatively taught.
Do not rev the engine while adjusting, keep it at idle.
T.
T.
- Toddh
T.
T.
The following user(s) said Thank You: KEL
- KEL
12 years 5 months agoToddh wrote: I used to adjust manual camchain tensioners by:
T.
Thanks Todd. I shall try that today.
That's the only chain in the motor that could be making that chainy noise isnt it??
There isn't a primary chain or anything is there?
- RickG
There are other chains. Drive chains from crankshaft to an idler shaft and from there to the clutch shaft but if they are lose they thump more than rattle.
Neither of the drive chains have tensioners.
- KEL
12 years 5 months agoRickG wrote: There are other chains. Drive chains from crankshaft to an idler shaft and from there to the clutch shaft but if they are lose they thump more than rattle.
Thanks Rick. Its more of a rattle like a primary chain rattle on a harley or triumph so I guess it must be the cam chain rather than a primary chain.
I don't want to play with it just yet as it hasn't really run for over 10 years.
It may well settle down.
