Stator oil leak FIXED! 7 years 7 months ago #14404
  • kza13
  • kza13's Avatar
  • Thank you received: 97
The "German" shop for 13 parts has got new grommets, saw it on his site, just thought i'd mention it
Stator oil leak FIXED! 7 years 7 months ago #14410
  • Thank you received: 181
Well, it's leaking again.
From ricksmotorsportelectrics.com/Rebuilt-OEM...le-Kawasaki-Stator-2...
KZ1300 stators come in two different widths, 18,19 and 23,24 mm.
Mine is 19 mm. The Ricks part number is 21-242. ~150 USD.
They have grommets and will sell them for 5 USD each.
Stator oil leak FIXED! 7 years 5 months ago #14840
  • kennyb
  • kennyb's Avatar
  • Thank you received: 8
Thanks for the tip. Cured my chronic oil leak that I was struggling with.
Stator oil leak FIXED! 7 years 5 months ago #15018
Well, the fix sure didn't last long.
I found some new grommets and will install as time allows.
Stator oil leak FIXED! 7 years 5 months ago #15022
  • rdbhere2
  • rdbhere2's Avatar
I've been battling a oil leak from the bottom of my stator cover. Some of thes3 covers weren't machined correctly and have gaps at the bottom of the cover.
Stator oil leak FIXED! 7 years 5 months ago #15028
  • Yaegunp
  • Yaegunp's Avatar
  • Thank you received: 32
I found that my covers had micro hairline cracks that produced leaks, which are near impossible for someone with failing eyesight to pickup unless using a magnifying glass. Then when I pulled the covers I could see where PO's had tried to fix them with metal weld. These bikes are getting on now and that aluminum doesn't stand up to the test of time like some other metals. I busted the circular housing where the thermostat goes by using an o-ring that was a bit thick for the job. The covers where the clean-air system is on the cylinder head cover have a tendency to break as well when using gaskets that are too thick. The gaskets that come in the Athena kit are like this.
1983 Z1300 A5 plus Sidecar.
Time to create page: 0.077 seconds
