Spark plugs. 8 years 7 months ago #9219
  • paulb
  • paulb's Avatar
  • Thank you received: 19
Hi
guys been trying BPR5ES plugs but still struggling with fouling of the plugs on initial starting and low speed, once the bike has started seems to be okay so I am thinking of trying the Iradium plugs , I saw mentioned earlier in the post eix8s can someone confirm
these are correct also any of the uk guys recommend a supplier
many thanks
Paulb
Spark plugs. 8 years 7 months ago #9222
  • McZed
  • McZed's Avatar Topic Author
  • Thank you received: 26
I used BR8EIX iridium plugs in mine and it's running well. I bought them on e-bay. item No 151093036118
Z1300 UK
Spark plugs. 8 years 7 months ago #9223
  • paulb
  • paulb's Avatar
Thanks for the reply, I will give them a try can I ask what you were using previously
thanks
Spark plugs. 8 years 7 months ago #9224
  • bassie20
  • bassie20's Avatar
  • Thank you received: 6
paul, I have the same problem, let me know if the iridium plugs make a difference.
Spark plugs. 8 years 7 months ago #9225
  • McZed
I was using the same plugs you are, had the same problems with them too. :dry:
Let us know how you get on the new plugs.
Z1300 UK
Last edit: by McZed.
Spark plugs. 8 years 6 months ago #9280
  • Thank you received: 356
If your bike is fouling plugs when cold then its best to get that sorted before buying new plugs as you may well just foul them too.
Try screwing mixture screws in 1/4 to 1/2 turn and trying it.
Make sure 3 chokes are 100% closed when off.
Check float heights.
Try starting bike with NO choke or very little choke and warm up slowly...........you will be amazed how much good this will do for your bike as it lowers the amount of fuel into the cylinders which causes fouling.
Last edit: by strate6.
Time to create page: 0.102 seconds
