GM HEI ignition module on kz 1300 8 years 7 months ago #8821
  • agmonmarine
  • agmonmarine's Avatar Topic Author
  • Thank you received: 14
I have replaced my IC igniter with 3 GM HEI 4 pin ignition module using the same pickups with great results so far.
I had a problem in high Rpm when the engine looses power and now it's gone.
This is from Lou Dudzik web site, he did this mode for a KZ 550 which using the same pickup coils as the 1300.
home.comcast.net/~loudgpz/GPZweb/Ignition/GPZgmHEImod.html
Good solution and the module price is $35-60 depends on the brand
GM HEI ignition module on kz 1300 8 years 7 months ago #8823
  • Thank you received: 1028
Nice job there Mister!! Looks like a perfect work around for some of the aftermarket coils the guys want to use. Issues in the past have been with trying to use the 2-2.2 ohm coils with the old ignitor and frying the transistors in the ignitor. I'm guessing the GM HEI ignitor has transistors that can carry higher amperages . I'm keeping this post handy for my machine. I've got a set of AW82 coils from a CBX to go on and they Ohm out at 2.2 so I'm right on the edge with these. I was going to put in .5 ohm resistors, but maybe I'll go this route. Thanks for the info!!
GM HEI ignition module on kz 1300 8 years 7 months ago #8855
  • brandonsmash
  • brandonsmash's Avatar
  • Thank you received: 8
Cool! I've been trying to decide whether to go with the GM pack or with a set of Honda coils. I have both sitting around my shop.
GM HEI ignition module on kz 1300 8 years 7 months ago #8856
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
  • Thank you received: 274
Hi agmonmarine,
Whichyear is your 1300? Mine is an 81 which uses a "Hall Effect" pick up. I'm told that this sort of pickup is limited to only the 81's.
Thanks
GM HEI ignition module on kz 1300 8 years 7 months ago #8857
  • agmonmarine
Hi there, my bike is a 1979 KZ1300 with the ignition pickup coils located under the intake manifold.
I use the Harley Davidson twin fire ignition coils that came with bike and it seems to work very well.
GM HEI ignition module on kz 1300 8 years 6 months ago #9426
  • mmoody66
  • mmoody66's Avatar
  • Thank you received: 0
Hi
Help please purchased bike in boxes 12 months ago getting it back together don't like the look of much of the electrical equipment
Can I fit HEI. Ignition to A3 with pick ups on side of engine and the larger igniter ???!
Also the voltage dropper / stabiliser for the instruments are there any mods or alternative parts I don't fancy buying another used one
Thanks
Time to create page: 0.111 seconds
