touringguy wrote: When it's hot and won't start, starting fluid won't start it, either. I've tried that. but after it has cooled down a while, starting fluid will work. Because the coils have recovered enough to produce a weak spark, but a spark strong enough to ignite a highly-flammable fuel? If I let it cool down all the way, and it will fire back up without starting fluid.
I've just about decided to replace the coils with a Dyna or Accel kit this summer. So I'll be asking for advice on that process -- which brand is best, how they mount, etc.
I've also noticed that my gas mileage has gone down the tubes -- more evidence of poor ignition.
First, coils don't "recover" I've never seen a coil go bad because of heat and then ok when it cools. It's obviously a heat related problem and I suspect fuel related BUT I wouldn't rule out compression related now that you tell me your fuel consumption is in the toilet. I'd also suspect compression if you've been playing with ether. My personal preference for "starting fuel is a spray bottle like the one produced by WD40 and put gasoline in it, then just spray the carbs lightly. If it won't go with gasoline, then why go any further?
If you want to go and change the coils for a piece of mind that's not a bad idea anyway. The AW-82 coil option is also a good one. Z1 Enterprises sells a three pack kit with solid core wires for around $98 U.S. They OHM out at 2.6 ohms and can be used without the ballast resistor. There are a few members on site who've done this one mod and are happy. That's the way I'm going. Like the price and a chance to eliminate the ballast resistor, plus the fact that they are physically the same size as the Kawasaki coils and mount in the same place with no modifications to brackets etc. . TrikeBuilder was writing up a tutorial on the pros and cons of the "modified ignition systems" but hasn't finished it yet. He brought up an interesting point about the repercussions of not having the ballast resistor in place and I respect his opinion very much. I hope he chimes in here with his thoughts again on running without the ballast resistor.
Anyway, I'd really like to know your compression readings hot and cold and while I ask that question, I'd also like to reinforce my belief in the leak down test being even more important than a compression test. Leakdown testing will show ALL of the defects in piston ring sealing, faulty intake and exhaust valves, head gaskets, cracked heads or cylinders and "tell" you where the mechanical problem is.
Sitting on the sidelines now waiting for your next post.
Kawboy
